New Build for Day Trading
jabronidan
I haven't built a rig since 2004 or 2005 so excuse me for being so out of the loop.
I need a new machine for trading. I will be buying 3 monitors so I will need a video card that can support that.
I'm looking at picking up:
CPU- Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W
Mobo- ASUS P5Q LGA 775 Intel P45 ATX Intel Motherboard
RAM- mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Hard Drive- 74GB Raptor or SSD?
Not sure on monitors (3 19 inch ones would be nice) or a video card. Also any recommendations on a power supply and case?
I would also buy a decent set of speakers. I like to listen to music while trading.
I want to keep this under $2,500 for the entire package. I will only be trading on this machine, using all 3 monitors at once, running Thinkorswim (I trade futures.)
Thanks for any and all advice.
That system is slightly overkill for a trading machine, but all in all good parts. You could drop down to an E7200/E7300 if you wanted.
You don't need an SSD nor Raptor, although they are getting cheaper by the day. The newer 7200RPM drives that use platter densities of 320gb, or greater, are only slightly slower for much less cost.
To run 3 or more monitors, you'll likely need at least 2 video cards unless you go with a T2G or similar. A standard PCI vidcard would be fine for the 2nd vidcard, but you should get two cards of the same family, to make driver installation less comlicated.
I'd invest more money into the monitors instead of the system. If 19" LCDs @ 1280x1024 are good enough for you, then go for them. However, the two systems I've built for traders both use monitors with much higher resolution (4x 20" @ 1600x1200 each; or 20+30+20 (1200x1600 + 2560x1600 + 1200x1600); although, I think two 24" @ 1920x1200 would be good, too).
I think I will go widescreen.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116391
Three of those viewsonics. If I ever need a big one, I'll get one. I'll also get 2 9600GT's to run my monitors, why not, I might want to play a game or two once.
I need something to hold the three monitors. I can't find anything nice unless it is from a company that makes them such as Digital Tiger or these guys http://www.customtradingcomputers.com/clearview_monitors.php. I could just do that. I think that may be better.
Thing is, I use each monitor for a specific purpose. The one on the left is to make a trade, the middle is the 1 minute chart, and the one on the right is a 5m, 15m, 30m, 1h, etc chart, I switch it whenever I want. I prefer widescreen and 19 is pretty much the perfect size for what I do.
i would use an AMD 780g chipset motherboard adn add a 4x50 video card.
the 780g chipset will do great with any video content...... and the video card will all for 3 monitors.
i had 19" WS but the resolution is crappy, get 3x22" i have seen many 22" for less that $200, i had an acer that was nice.
I would use 3gb or 4gb of RAM, 3gb for 32bit OS or 4gb for 64bit os.
Then get 2 seagate 7200.11 perpindicular drives and run RAID 0 for parity and uptime, run on the motherboards chipset.
easy to build the PC for less than $700 and then $200x3 for $600 which is way below your limit.
