New build for a friend
Neex
Hey guys I need helping building a new setup for a friend as a gift.
Mainly surfing the web, but would like something that would be able to handle mid-tier level gaming.
$600
There really isnt a budget, id just like to try to keep it as cheap as possible.
South NJ
CPU, Mobo, Case, PSU, HDD, Moniter, GPU, Keyboard/mouse.
8gb ram - have to check what model number
6) Will you be overclocking?
no
Need one, thinking of a nice 21" or even 19"
Planning next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
WiFi capability is a must!
Yes, win 7 64bit pro
Additional Comments:
I was looking into the AMD apu but unfortunately i don't know much AMD CPU/APU/Mobo. Again this will mostly be used for web browsing but would like the option on there to run games at a decent level.
Not going to give specific advice, but I would go for the nicest screen you can get for that budget (cheap 24" with IPS panel). I have noticed people always get amazed by the screen you give them a thousand times more than the actual computer. Maybe build it as a system that is not amazing for gaming but expandable and let him throw in a GPU later. I also try to always include an SSD in every system I give to people, almost not usefull for gaming, but everything else is much faster and feels snappier.
