web browsing, word processing, some gaming probably (diablo 3 when it comes out, Star Wars MMO)
would like to stay under 1200 for everything, peripherals included preferably.
3) Where do you live?
Long Island NY
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, PSU, Mobo, Case, Ram, GPU, optical drive, monitor... brand new build, so EVERYTHING.
nothing being reused.
6) Will you be overclocking?
should i be? i'd consider it.
probably between 21" and 25", wanna stay below 150 for the monitor, 1080p, 2ms refresh rate...
within the next few weeks, waiting on a refund check from my college
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
not quite sure. if i get the HD5850, i won't crossfire immediately, but if i go with 4850's i'll probably crossfire. i don't really understand it though. I also want to run 8GB of ram, just because. someone talk me out of it?
10) Do you already have a legit and reusable/transferable OS key/license?
yes, and i'll use the student upgrade to windows 7
thanks guys in advance. this is my first complete build, but i've installed a GPU and RAM in a desktop before many moons ago.
Long Island NY
