New Build Does NOT Power up?
aznknife
Bad Trader
I got all the parts for my new rig yesterday. So I started building it today.
Specs
Antec 900
2X 2GB Corsair DDR2-800 RAM
Intel E2180
ECS 7050 GEFORCE Mobo (Based on 610i)
8600GTS XXX 256MB
Antec Earthwatts 500W Power Supply
I got everything hooked up when I switched the power switch the LAN Ethernet switch lights up. And no power when I try to turn it on.
What can be the problem?
You sure you have the 4 pin motherboard ATX connector in? Processor seated properly? HSF on properly with thermal paste and fan plugged in? That and min config and one stick.
Yes there is thermal grease. HSF is on. Yes 4 pin is connected. Motherboard is getting voltage.
Can't jump start it!!!
Took a screw driver used the tip on the third pin on the mobo F Panel.
Started up right away :)
