New build - critique welcome
Khanmots
It's been too long since I did my last serious build, so I've had to do a lot of cramming trying to figure out what's been going on with the tech lately. I *think* I've got a decent build together, but I thought I'd ask for feedback, as I'm undoubtable overlooking something :D
Looking at:
ABIT IP35-E
E6750
EVGA 8800GTS 320 http://www.newegg.com/product/product.asp?item=N82E16814130038
Corsair 520HX
4x1gb ddr2 800 at 4-4-4-12 timings ( 2 sets of http://shop4.outpost.com/product/5283387 )
Going to try Vista 64-bit Home Premium, with XP-pro as a fallback if vista still has stability issues.
I'm running dual 20" displays at 1600x1200. Am I going to want to change the vid card to a 640 for future games? Looks like most current games I'd be ok with... but I'm not sure about 6 months from now... and if I ever do break down and get a 24" to go in the middle, I'd definately want the 640?
I don't see myself ever using SLI, and while I'm not planning on OCing now... I might decide to give it a shot a year down the road, so if I can get OCable components for not much more I'd be willing to (don't know how well what I've outlined would OC)
So... given all that... thoughts on the appropriateness of these components? Are they decently balanced? Anything I'm overspending on (doubtful...)? Anything I'm underspending on (most probably...)?
Thanks! :)
The GTS 640mb is fine for your current monitor. If you plan on getting a 24", you'd be better served by the GTX. However, if that 24" upgrade is a while from now, don't bother with the GTX just yet. Upgrade the card when you get the new monitor. If you're going for larger than 24", you'd want an SLI board.
For OC'ing, pickup a Scythe Ninja Plus Rev.B, Tuniq Tower, or Ultra 120 Extreme + Scythe S-Flex fan, along with some AS5.
Nice choice of parts, btw.
Ok, the 640 GTS it is. :p
Also... am I overlooking anything about that mb? I haven't noticed many peeps going with it as opposed to the IP35 or IP35-Pro, but I wasn't seeing that it was really lacking anything I'd need?
As for the choice of parts... it's all come from lurking on these forums for the past week :p
Few more questions...
Does anyone have any experience with EVGAs stepup program?
And would I have any issues with a P180 or P182 and a possible future GTX? I've read that they will fit it, but that running cables can be really rough, and that it requires removal of a drive cage. Any other better case recommendations? I'm wanting a quiet case with solid build quality that isn't all riced up :p
