New Build, any help, thoughts, commments etc ??
FalcX
Some Gaming, menu programs, minor video editing, etc, webbrowsing, etc, etc
None in place, but around $2000 cdn.
Canada
CPU, HSF, HD's, Ram, Motherboard, GPU, Case, Power Supply, Sound Card, Drives
N/A
6) Will you be overclocking?
NO
BenQ 24in 1920x1200
Ordering next couple days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3, Sata 6
Yes, Win 7 Pro 64 bit
I am planning a build that I expect to last me at least 3 years. I do some gaming and am not planning to overclock. I like my builds to be as cool and efficient as possible without overclocking. I only want a single gpu and want it to be able to handle games now and in 1 - 2 yrs, and possibly look at a dual monitor setup.
I pretty much have everything picked out but am still unsure of a motherboard. Obviously im about quality and dependability and am not looking just for something to get me by for now.
CPU: 2600K $305
MB: Asus P8Z68-V PRO $200 OR MSI Z68-GD80 G3 $240
RAM: GSKILL RIPJAW X 8 GIG 1600 $63
GPU: MSI GeForce GTX 580 Lightning Xtreme Edition $599
PS: Seasonic X850 or will the X760 be enough ?? $199
SSD: Crucial M4 SSD 128GB ........already purchased on sale for $159
HDD: WD Black 1 TB WD1002FAEK $85
CASE: leaning towards the HAF X $189 but am interested in the HAF 912 Advanced
HSF: CM Hyper 212 $30
OPTICAL: LG BH12LS35 Blu Ray Writer $90
Sound: ordered a Creative Labs Titanium Fatality PCI-E 7.1 $144
and some arctic cooling mx4 paste...
Like i mentioned I am still unsure of which motherboard to get. I feel confident with everything else and am loooking for input on these things if there are any known conflicts, etc.
I appreciate all the replies and recommendations. Thanks
Unless you are doing a lot of video encoding/editing type work, you wont see a difference between the 2600k and 2500k in regular working environments. You also wont notice an increase in gaming. So, unless you are doing serious 3D rendering and video editing/encoding save the $100 and get the 2500k.
None of the requirements you mentioned justify spending that much money on a motherboard. A Z68 pr P67 board in the $120 - $150 price range will do everything you need.
No need in spending more money on DDR3 1600, when DDR3 1333 will perform just the same under normal circumstances. DDR3 1600 is only faster under the most ideal situations (benchmarks) and even then it's less than like 3% faster.
IMHO, the GTX 580 isn't worth the money. Go with a 6970 or 6950 instead, unless you plan to play serious games at the highest details possible, even then the 6970 is on the heels of the GTX 580 and costs less.
That PSU is a good PSU, but it costs too much money at $199. Look for a Corsair 650 V2 or 750 V2, please note the V2. They should be under $150.
Good choice on the SSD.
Get the Samsung F3 1TB hdd, it's cheaper and just as fast as that WD Black drive.
The HAF X IMHO is over priced. Go with the cheaper HAF 912 or choose one of these cases.
$60 - NZXT Source 210 Elite ATX Case
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$70 - Lian Li Lancool PC-K58W ATX Case
$70 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$100 - Lian Li PC-7FN ATX Case
$110 - Lian Li PC-60FN ATX Case
$113 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$110 - Fractal Design Arc Mini Tower
$120 - Corsair Carbide Series 400R ATX Case
$130 - Fractal Design Define R3 Black ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$150 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
The CM 212+ is a great cooler for the price.
IMHO, the on board sound will do everything you need. No need in spending $144 on a sound card when you wont even make use of it really.
The paste that comes with the CM 212+ is good enough, no need to spend more money.
