New build and some questions
Vaporz
Doing a complete upgrade, building it myself for the first time.
311800 Antec Performance One P180 Miditower
325457 Asus GeForce 7950GT 512MB GDDR3, HDCP, PCI-Express, 2xDVI-I, Tv-Out, Retail
321779 Asus P5B DLX/WIFI-AP, P965, Socket-775, ATX, 2xGbLAN, SATAII, Firewire, PCI-Ex16
312054 Corsair TWIN2X 6400 DDR2, 2048MB CL5 Kit w/two matched CM2X1024A-6400 Dimm's
315688 Fortron/Source Epsilon 600W, Blue Fan, Active PFC, ATX/EPS, SLI, 20/24pin
322631 Intel Core 2 Duo E6300 1.86GHz Socket LGA775, 2MB, BOXED w/fan
325546 NEC DVD-brenner AD-5170 IDE Black OEM DVD+R/+RW/DVD-R/-RW (Dual layer)
320709 Seagate Barracuda 7200.10 320GB SATA2 16MB 7200RPM
I have keyboard/mouse/speakers/monitor, a 200GB sata & a 120GB ide drive from the previous PC.
What I'm wondering is:
With DirectX10 coming "soon", should I go for a cheaper Gainward GeForce 7900GS 256MB,1,2ns DDR3 ,PCI-Express, "BP7900GS-512-TV-DD-GS" or a Asus GeForce 7900GS 256MB GDDR3, PCI-Express, 2xDVI-I, Tv-Out, Retail or even a 7600GT and get a Dx10 capable card in 2008 or so? A 8800 now is too expensive.
I might do some small overclocking. I'm buying some artic silver thermal paste, and am I right in thinking that the p180's fans & the stock cpu fan are enough air cooling?
Is this system pretty upgradeable in 2-4 years without replacing mobo/psu/tower? Adding 1-2GB ram and maybe a core 2 quad/better c2 duo?
Edit: I have an audigy 2 soundcard, is it still better than the builtin sound from the mobo?
Other good mobo choices would be the DS3 or P5B-E. They're much cheaper and can both OC pretty good. If you plan on upgrading to a DX10 card within 3 months, go with any eVGA card and use their step up program. Yes, the fans in the P180 and the stock intel hsf is adequate cooling. How far do you plan on pushing the E6300? If you'd like to go past 2.8Ghz, I'd suggest getting an aftermarket HSF (Tuniq Tower, Zalman 9700 or 9500, Scythe Ninja Plus RevB or Infinity). In 2 years, I'm guessing quad cores will be dirt cheap, but Intel's new socket and DDR3 should be out by then. Try onboard sound. If you dont like it, add in your soundcard.
I agree with your choices but would do some minor adjustments:
- If not 100% needed, get a cheaper board. The DS3 is a good choice for much less.
- Videocard. Tough one. I'm a firm believer of not buying a 8800 card right now. DX10 games are WAY far off and once they hit, the 8800 will be outdated. Get a cheaper card and be happy when it's time to upgrade for DX10 (end of 2007-Spring 2008) games.
Other than that, maybe the Antec Ninehundred instead of the P180?
I already ordered the case along with the HD (cheaper from a different site I'm ordering the rest)
Going to order the rest soon, I'm pretty settled on a P5B-E Plus and the mentioned ram & cpu.
Just have to figure out 7900GS for now vs 8800GTS... Wont the next cards out be more mid-range cards than the 8800s? A bunch of reviews show impressive 8800 performance in DX9 games, which might even make it worth it though there's probably no DX10 fun before 2008... But I'm pretty uncertain
(yes, Norway is expensive, converted from NOK to USD)
Asus 7900 GS: $275
Asus 8800 GTS: $654
Just using these two as an example: there's not going to be something superior to the 8800 for $378 (difference) as early as end of 2007? Might as well enjoy the 8800 until then and past? Assuming I won't have problems with drivers as some...
