New build advice needed.
mimoawi
Nice to be back on forum again.
Im planing to build a new PC for gaming and wmware.
Gaming and VM
2) What's your budget? 1000 /1300 euros
The Netherlands
CPU (im leaning toward intel core i5-12600kf if budget allow it ) , GPU RTX 3060,Motherboard , ram, case ,CPU cooler and PSU.
HDD x2 samsung SSD
6) Will you be overclocking?
no
3440x1440 34 inch
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
M.2 sockets and usb-c connector to front panel .
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
i own a liget reusable version of windows 10
thanks in advance.
