uncoolfish
- Jan 31, 2005
Hi, I just upgraded from an Asus A8N-E to Abit AN8-SLI today, and there are two very subtle problems. Maybe you experts can figure this out.
1) There is a delay between pressing the power button and the system turning on. If I unplug the system and replug it, the POST code settles on 0.1. But when I press the power button, it changes to F., and after about 30-40 secs, the system powers on just fine. I tried to see if the power switch connection to the motherboard is wrong, but that didn't help. The really strange thing is twice the system powered on instantly!
I searched some more about this issue. Could this be caused by the power supply? I have an Antec Neopower 480W.
2) I can not get the front headphone to work. The front microphone works just fine. The front panel audio connection on the sound daughter card is:
audio mic
ground
audio mic bias
VCC
speaker out right
speaker out right return
X
NC
speaker out left
speaker out left return
On my Coolermaster Centurion 5 case, I have it connected as:
Mic -> audio mic
Mic Power -> VCC
Ground -> ground
Right Out -> speaker out right
Right Out (in series with the above one) -> speaker out right return
Left Out -> speaker out left
Left Out (in series with above one) -> speaker out left return
With the above configuration, I get audio from the back panel connection, and front mic works. But front headphone doesn't work. I tried to disconn the return channels, that only stopped the back panel connection from working, and the front still doesn't work... I have no clue what could be wrong here...
Thanks in advance for any help!
audio mic
ground
audio mic bias
VCC
speaker out right
X
NC
speaker out left
Mic -> audio mic
Mic Power -> VCC
Ground -> ground
