New build 99% complete.
http://www.hardforum.com/showthread.php?t=1432314
Link to the original thread.
Here ya go. I still need to get the custom case wrap done and put on, but its close nuff to show it off a bit. :D
I'm really happy with how it all turned out other than the heat issue. I will prob save my pennies and build a nice custom water cooling setup. Thinkin a custom aluminum box, automotive heater core with a couple 120mm fans. For now...this will do.
With the case cover off.
Looks great.. . . which orange fans are those... i'd like a few
also what kinda rough dimensions is this thing? now that I look at it, looks nice and small and perfect for taking places... smaller than i would have first guessed
270 x 212 x 393 mm
http://www.phoronix.com/scan.php?page=article&item=silverstone_sugo2&num=1
The fans are actually red led. http://www.newegg.com/Product/Product.aspx?Item=N82E16835200046 The two on the top side are these...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999453 The single in the HDD cage is one of these. I would suggest buying the Logisys over the Rosewill. They are a bit more quiet. One thing I DO like more about the Rosewill fans...the wiring has some REALLY nice sleeving. Both brands' leds are as bright as one another. Thanks for the nice words.
