New build 3750K
endy0430
Hi I wanted to get some advice on a MOBO for my new build. Going with the 3750k. Mostly for video editing, graphic design and some gaming not much. Don't plan on overclocking I might just to try it out. Please lets hear some suggestions thanks.
I was looking at the Sabertooth but is a bit pricey......Nice board
The extreme4 doesn't exactly use high quality components although the board has great value for the features it gives. UD3H is actually the opposite, it has great build quality and features, but gigabyte's software is really old school and is a big let down, so I wouldn't choose that either.
You may wanna consider ASUS's P8Z77-V/V-Pro or the Extreme6.
when did intel release a 3750k?
I would also recommend the MSI Z77A-GD65 or the GD55.
To be honest, unless you plan on overclocking there really isn't much need to buy a high end board. Quality-wise, anything from the major manufacturers is going to be good enough, so you can really focus on features. Do you need anything special (extra SATA ports, extra USB 3.0, etc)? Is there any reason why you'd need anything more than one of the lower end Asus models, for instance?
Something like the P8Z77-V LX for $129 after rebate? It doesn't sound like you'd notice the $100 difference to the Sabertooth.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131824
