New audio player suggestions
Ckamc
Today I had the last straw with Winamp. The most annoying portion of it has to be it duplicating media files thus creating ciaos with my playlists.
I would like something user friendly, does not consume a large amount of resources, and has been updated within the last 3-6 months (aka new version).
I am still dinkering around with foobar2000 but it isnt exactly your easiest to skin/personalize media player. However it does use bare minimum resources(9,000k of memory according to task manager) .
Currently trying out Jetaudio, so far I do not have an issue with it. Interface is ok but I did notice in task manager it does use up a good 65,000k of memory).
Never liked WMP and I do not have a ipod so I really do not see the need for me to have itunes.
Thanks for your time :)
Aside from foobar, I would say MediaMonkey is good if you have a large library.
Coolplayer is a handy lightweight player that I used to use on my work machine. It works great for a small footprint.
Yes I have a LARGE collection... trimmed it down a month ago from 80 gigs down to 40.... still have over 5000+ songs.
WMP 11 gives me lip just as much as 10 and 9 did.
Ahh thanks for the reminder of coolplayer! I will look into mediamonkey as well.
foobar is now a project... too much to do to get it the way I want it.. Worked on jetaudio so now its down to 29k and I am sure it will go down further once I get a dedicated sound card.
ran across j river will review it later on today.
