New Ati Drivers Underscale Issue
topslop1
There is an option in the drivers under Scaling options (Digital Flat-Panel) and it is by default set to underscan. I need to put it to 0% Overscan so that the picture fits flush with my screen. When my computer goes into the screensaver/logon screen it ends up resetting back to 15% and I get a shrunken picture as soon as I'm done logging back on. I've set 0% and clicked apply a few times and it seems to not save my entry.
A bug with the new ati drivers or am I doing something incorrectly?
Well I gotta ask, if you set all of the driver options to their defaults, and then set the monitor to the defaults, what are you doing that is causing you to mess with the scaling? Are you not running your video card at the correct resolution for your monitor?
ATI drivers seem to think that anything plugged into hdmi need underscaling. Try a DVI cable if you have one.
Shit, I don't have a DVI cable anymore and am using an HDMI cable. I'll pick up a DVI off of ebay for the cheaps. I'll need a male to male correct?
