Jucius_Maximus
- Dec 30, 2006
Hello. I've been reading threads on hardforums for over a year now but this is the first time I actually have to ask for help. Been building / troubleshooting computers for over 10 years now so I can handle technical advice.
Been helping my bro with his new Christmas hardware and we are getting nowhere fast. The machine is simply not booting. Push the power button and the fans + HDDs spin up but there is NO beep and the screen remains blank.
This is my first experience with a PCI-E / Dual Core setup.
Specs:
ASUS M2R32-MVP ATX AM2 Xpress 3200
Athlon 64 X2 4200+ Dual Core AM2 Windsor 2.2GHZ 2X512KB 89W 90NM Retail
ATI Radeon X1650 Pro (PCI-E)
Corsair XMS2 TWIN2X2048-6400 2X1GB PC6400 DDR2-800 CL 5-5-5-12
I have tried 2 PSUs with it:
Antec TruPower 430W - Might be underpowered; I am using the 20/24pin converter for the power.
Fortron FSP FSP600-80GLC 600W EPS12V 24PIN Power Supply - Not underpowered; You must snap an extra 2x2 pin power connector onto the 20 pin power connector to make a 24 pin connector. (I have tested the individual voltages on this snap-on connector and they are correct.) But this PSU lacks the extra 2x2 pin 12V power connector that connects by the video cards - the mobo manual says this connector is essential otherwise the machine will not boot. (The Antec above DOES have this connector)
Things Already Tried:
1. Reset the BIOS data. - No effect (I removed the battery, shorted the jumper for 10 s and then replaced the battery after 20 mins.)
2. Try only with 1 stick of RAM and move it to all possible slots. - No effect.
3. Re-seat the CPU, HS, Video, Ram, etc. - No effect.
4. Swap the above power supplies - No effect.
5. Try multiple monitors, DVI/VGA converter, etc. - No effect.
Earlier on I was trying to boot it with the Fortron PSU without the extra 2x2 power connector and of course it was not working. Maybe that had a bad effect? I also kinda knocked one of the capacitors on the board a bit when I was reinstalling the heatsink during troubleshooting... it did not break but that made me uneasy... though the board was already showing problems before this point.
Any help as to what to do to get this machine running would be much appreciated.
Specs:
