new am2 build
R3d
Hey guys i'm going to making a new build here in a bit.. i'd rather stay with AMD over Intel.. rig will be mainly for gaming use..
here's what i have so far and budget is at most 2500 w/taxes and shipping
parts from www.directcanada.com
Team Xtreem PC2-6400 2GB 2X1GB DDR2-800 CL 4-4-4-10 240PIN DIMM Dual Channel Memory Kit 2.0-2.2V
Silverstone Zeus ST75ZF 750W ATX12V 20/24PIN Power Supply W/80MM Fan Active PFC Quad SLI Certified
ASUS Crosshair ATX AM2 Nforce 590 SLI DDR2 2PCI-E16 PCI-E4 3PCI SATA2 GBLAN 1394 Sound Motherboard
Amd Athlon 64 X2 5200+ Dual Core Processor Socket AM2 Windsor 2.6GHZ 2000FSB 2X1MB 90NM Retail Box
Zalman CNPS9700NT Copper CPU Heatsink 110MM Fan LGA775 AM2 S939 1250-2800RPM 19.5-35DBA Green LED
Evga E-GEFORCE 7950 Gt Ko 560MHZ PCI-E 512MB 1.45GHZ GDDR3 Dual DVI-I Hdtv Hdcp Rohs Out Video Card (for now till the newer dx10's come out and are actually worth picking up)
total for these parts is 1580$ CDN
case: now i'm torn between the CM stacker 830 black or the silverstone TJ09 black w/window
cm stacker is 263$
TJ09 is 297$
which case would offer better air cooling and possibly more room for watercooling if i were to get into that.
from the other specs.. there anything else anyone would add or recommend?
i'm not 100% sure what i want to do with the harddrives yet. either pick up 1 150gb raptor and another larger drive for space or pick up 2 150's for raid0.. suggestions for this would be great too.
thanks guys :)
Get a C2D, or if you've got your heart set on AM2 get a 4600+ X2 and overclock it to to the same speed as the 5200+ X2 for a lot less money. I have an AM2 and I wish I didn't buy the thing as I'm going to have to upgrade to a new motherboard etc for new CPUs in the future, not to mention they aren't as quick as C2D :)
what do you mean not as quick as the C2D Isnt AM2 currently the best socket for processors out their in the market and C2D still stuck with LGA 775 socket while amd 940 contacts and DDR2 ? and why would you change your motherboard?
If you had read what the op posted he said he prefered AMD to Intel.
why not get the 5200 and OC that?
cm stacker is 263$
TJ09 is 297$
thanks guys :)
Add more ram if you have a $2500 Budget shoot for 4GB, the more ram the better. And I would get one raptor and another larger HD. I would also add some SATA DVDRW drives to ditch the IDE cables. Other than that I see nothing else wrong. Both of thos cases look small to house everything and have the best airflow. The silverstone you choose is a midtower and the CM stacker has issues with some power supply sizes but it is a full tower. So I would choose the stacker but make sure you power supply is compatible.
LOL
I hope you're being sarcastic, but if not, well, let me just say some people really need help... ;)
Hey all, thanks for the reply's...
i was originally planning on making a C2D build, but have changed my mind to stay with AMD.
has there been any issues with the crosshair board?.. i'll probly get the single raptor and get a couple storage drives or just use my other comp and set it up as a file server(probly just do this in the end)
are there known issues with the cm stacker and the SS zeus 750w?
would i need the 750w or would the corsair 620hx be good?
