New A04 mATX Sandy bridge build
Mosher
Hi guys, I thought I would just make a new thread to get picks up of all the new hardware I just got up and running. I think this is going to be a great machine, and it's still very much a work in progress. So things like wire maint. haven't happened yet so if it looks like a rats nest... well... I'll be trying to fix that! Ideas on wire and cable routing especially from other owners of an A04 are very welcome. I love this machine though. Small enough to fit on the top of my desk and fast enough to run everything I do. I'll talk more about near future plans further down, but for now on to the Pics!!
Pile o goodies!
Shown above are the following parts :
CPU = I5-2500K
HSF = Cooler Master Gemini II S
MB = Asus P8P67-M Pro
Mem = 8GB Patriot Sector 5 (9-9-9-24)
Video = PNY GTX 570 (Where the big money went since it is a gaming machine :D)
Case = Lian Li A04B
PSU = XFX 750W Black Edition
Carry over parts from old machine HDD Seagate 1TB 7200rpm and ASUS Blu-ray Optical drive
The Case! Lian Li A04
Sides off
Front Bezel off
Moving on a bit, Motherboard, mem, and CPU cooler (Pre-installed)
CPU up close
CPU on the board, with HSF and memory installed
Now the big ticket item, the Video Card!
PSU, this thing is awesome. [H]ardocp is right to love these PSU's.
Opening the box, the fan greeted me!
And a side shot
Here are some assembled pics
Well I hope the links work and someone gets something good from this. I have some mods planned as well which is why at least atm I haven't even bothered to put the sides back on.I am going to have some fans going into it, I need to actually do some real Wire management (Once again tips are welcome) as well. I also am hoping to make room in the back for a 92mm fan, and mod the side panel for a window plus extra 120mm fan. I may even figure out getting a Corsair H70, or even a custom loop in there for good measure. All in all I am very pleased with performance, so far it's hit 4.4 with the Gemini II I just don't want to keep it there as temps seem to creep up into the high 70c's under prime 95. So I do think some better cooling is in order.
Well that's all for now.
Took you long enough ;)
I think your best bet for a H70 (or any single rad) would be the top panel. I'd have to look at the case again, but with the way your build is configured, I can't really see if anywhere else except maybe externally.
As for wires, try turning the bottom rack 90 degrees. You'll have more room to lay out the wires along the back panel. May get slightly better airflow across the hd too. Get the 24 pin as close to the back as possible. If you remove the top panel, there's a small hole up in the frame near the fan. You can probably route your 8 pin up through there. As for the rear fan, there should be a small gap near the pci-e slot between the gpu and mobo, your fan wire could route down through there. That's all I've got for now. I'll wait and see what you do :)
Thanks Will! That input is appreciated.
Yea it did take me a while /facepalm lol
Once I get some time, I'll start really trying to route cables. I don't think a rad will fit on that top fan as it would run into the motherboard. I do think I know how it would fit on the front with a little dremel action.
Do you get a high pitched whining sound from your XFX PSU? I had the 850W version but I am sending it back because it the noise really was unbearable after a while. May just have been defective, but the Corsair HX520W I have in there now is silent and no issues running all my hardware even with the 4.5GHz OC. Total power draw at the wall according to my UPS is around 450W in Crysis, no stability issues. Also the Corsair's cables are far easier to work with, the XFX's cable sheathing is way too thick. Only problem is having to use molex to 6-pin PCI-E adapters for the second GPU but not a big deal.
Thanks Simon!
There is 1 120mm in the top and I think I am going to leave it like that, I actually want to mod a 92mm into the back were the 80mm is, I hate the whirl of that small a fan.
Blahman - haven't had any issue's with the XFX whatsoever, I do agree the sleeving is crazy thick and might prove to be something of a challenge to get all routed as I'd like.
I have been crazy busy, I did get time to install some green LED fans I think they look nice. Problem is funds at the moment to do any modding really, and I need to get the P67 replacement action going
Contact Corsair, they will send you an extra PCI-E cable for free. I did it with my 520HX a while back when I switched to a dual 6-pin card.
Interesting, that's nice of them. However, I am using two dual-6pin cards, so a total of 4 6-pin PCI-E connectors are needed. It's not that I'm missing any cables, it's that the PSU only has 2 6-pin PCI-E output ports, so I have to use molex connectors + adapters for the second card. Unless you meant they actually have cables that go from their molex/SATA output ports to 6-pin PCI-E.
In any case, it doesn't matter because I now have a Corsair AX850 that I need to install :D
Turns out the HX520 wasn't quite enough juice for BFBC2 which saturates more of the CPU than Crysis and would cause the framerate to tank when there was too much power draw.
