new 9800pro glitches in games
Samnit
I just bought an installed a sapphire 9800 pro and have been having some problems.
I upgraded from a geforce4 ti4200 and took care to properly install drivers, using driver cleaner etc..
When I try to play jagged alliance 2, the game only appears in the top left corner of my monitor, with weird artifact lines on the top right corner, and just black on the bottom half. This is the same case in dxdiag's display testing except this only happens with the DirectX 7 and 8's display testing. DirectX 9's tests fun perfectly normal.
Another thing is that I run dual monitors, an LCD using DVI on the 9800pro, and a CRT using analog on a radeon 7000. The CRT when hooked up to the 9800pro in analog runs the game fine. The LCD hooked up with analog on the 9800pro work fine too. Thinking it was something to do with my LCD, I downloaded and installed drivers for the monitor but still I get the same problem in DVI.
Any suggestions would be greatly appreciated. Really hope I don't have to RMA the 9800pro.
Before RMAing, you might want to try reinstalling Windows (from scratch, after doing appropriate backups, etc.). Drivercleaner didn't totally work for me, and I ended up wiping OS and doing a fresh install, after I changed videocards. Or it may be a bug with DVI output, people I know with ATi cards have had some problems with the DVI output that didn't show up on the analog port. I really doubt there's something physically wrong with the card.
Good advice... I went from a NV 5900 to a 9800Pro and used driver cleaner... While I had no anomolies, the performance just wasn't there... Did a clean install and all was golden.
I've figured out that this happens anytime the video card goes into a 640x480 resolution. This can be game or desktop.
However, it doesnt look like the video card wants me to change to 640x480 via control panel. The only way it even goes into 640x480 for a moment is with an ultramon setting before it loads jagged alliance.
I'm hoping this piece of information would get me some answers.
Have you tried a different set of video drivers? If you don't really want to reformat you can always try a different set of drivers.
I recommend Omega drivers. I use them with my Sapphire 9800 Pro and never encountered any problems.
If it works (or doesn't) I still would recommend to reformat just so you can get the top notch performance from that card without any driver issues. And it's always better to start off clean.
Gonna try the omegas now, but yeah I'm thinking I'm gonna do a format. It's just that I have this computer set up so perfectly right now. argg
edit: I got it working now! I forced JA2 to run with a refresh rate of 70hz instead of 60hz using ultramon and it worked fine.
