master noran
- Dec 10, 2006
Ok, so I've have previous problems with the 4850 in windows 7, now I've moved on to vista and still the problem exists....
Ok so it all started with when I installed win7 it was on a clean PC, just built. I tried to OC via catalyst controller and everytime I tried to OC I'd press custom clocks and it would fail regardless, I could still set the clock I wanted though (this was with the win7 drivers) so I installed the vista 64 drivers, it solved the custom clock problem. Then at some point whenever I tried to up the clocks I'd get grey vertical lines, for about a min then the computer would restart. I just got vista and same crap, although I am using the drivers that came with the card. The card works ok on default though, the only scetchy problems I had were in crysis were it ran fine the entire game up until I get to the reckoning level were it would freeze for 20 seconds at a time even with the res and detail tuned down as far as possible. So should I attempt to RMA this thing or what? the store I bought it from won't take it back, should I contact sapphire?
