spacecadet said:If you don't mind me asking, where did you get the information about the x1300 not being adequate? Does that mean the x1800 cards work fine then? is it an ATI driver issue that should be fixed in future driver revisions or something intrinsic to the hardware?
If my 3rd LCD also has the same problem, i've got to assume that it's not the monitor. and i'll probably keep the one that doesn't have dead pixels. And i'll assume that at some point when i upgrade my video card and other components, the sparklies will disappear. that's probably the most reasonable option i suppose
Once you go 30", you can never go back.![]()
beesquee said:Got the same problem with mine. Although it's intermittent, they appear for a day or two and dissapear for a few. Not really that noticible except on dark colors.
Hopefully its a cable or card issue. Going through 3+ RMA's is such a hassle.![]()
Sapphire Radeon x1300, lower end but the box does say it supports the full resolution of the monitior.LittleMe said:what video card are you using?
YoureDoingMeDamage said:Wow what the hell is wrong with you? That is just stupid and useless. The 2007's look pretty gay next to the 3007.
wtf, you just spent 2K on a great monitor. pretty dumb to question whether you should or not OR to even have a lazy mentality towards getting the best out of your money.Seems like such a hassle. It may be a good idea though i suppose.
roflArchonius said:post more pics please, this is like porn to me.
bradtem said:Now my PS even though rated at 200w will do 15a at 12v, which is more than some 350watt supplies will do, but it does seem these cards are really pushing things -- and again to no purpose for somebody like me using his 3007WFP for non-gaming. SFF boxes tend to have power supplies like this. 350w is simply not available.
Pwahahahaha!J-Mag said:
J-Mag said:
spacecadet said:Well the 3007 and 2007 in portrait acutally match up exactly in pixels and physical dimension. I am unable to adjust the 2007fp too well because they are all on one mount...QUOTE]
The 3007 mount is not centered? I have my 2405 and 2005 on an Ergotron dual HD arm and the 2405 and the 2005 line up dead center when the 2005 is rotated and the 2405 is not. Im close to getting a 3007 and 2407 but may not if the 3007s mount is not vertically centered.
Tanquen said:spacecadet said:Well the 3007 and 2007 in portrait acutally match up exactly in pixels and physical dimension. I am unable to adjust the 2007fp too well because they are all on one mount...QUOTE]
spacecadet said:Maybe something to dow with the fact that the 2007fp mounting points aren't perfectly centered.
