New 2010 Build
Jbarns321
I plan on Vista with one 500gb hard drive and Mac OS X with the other. Think that would be hard to do. I have discs for both OS.
I am working on a budget of 900 dollars. Mainly going to be used for lower end games like RTS's and Sim type games. Possibly a little WoW.
Please leave any reccomendations for any changes that I might want to check out.
P.S. I already have a 9800 GT 1GB Vid Card. I don't think I will need much more. Also have Optical Drive
Sorry about the link.
Parts are as follows, with links.
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103680
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Heatsink- http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
PS- http://www.newegg.com/Product/Product.aspx?Item=N82E16817171032
Hard Drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
Monitor- http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
Alright one problem mate, I am pretty sure that you can not get Mac to run on a AMD based mobo / CPU combo.
No, it's possible it just takes a little bit of tweaking to get it to work. There are quite a few communities out there that make drivers for OSX to run on just about anything you can think of.
does osx support more than 4 gigs? and default vista 32 generally only sees 3 gigs though sometimes it registers there is more but i doubt its getting utilized correctly?
there is a ram combo with that mobo for $169.99
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.334441
4 gigs adata, never used them but varying reviews though i see there ram around a lot.
4 gigs gskill ddr3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
is another one a little cheaper , im guessing different timings or something.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
anyway your picks are pretty solid it seems. im not nuts about coolermaster psu, but a lot of people have them. just personal preference, they were not up to par a few years back, but they might have turned that around.
if your lucky that cpu fan for the pump or rad will mount to the side of the case since its already drilled for 120mm. not sure how big that water unit is, other than that i think it will fit everything in fine.
32 bit os systems ONLY sees 4 gigs of ram total. when you add a grafic card with f.x 1 gig of ram, 3 gb will show up in you os. you cant use the last gb. for that, you will have to go 64 bit.
I have a Vista 64 Professional or Ultimate Laying around I was going to use. If It is to difficult to go with a OSX on an AMD board then I have no problem switching my stuff around to work with a Intel Chip and Board. I was looking into the i5 stuff.
