new 2005fpw
powerade
how do i get to use the usb ports on the side ?? plugging stuff in wont recogznize it (sp lolzzzz) no driver disk came with the fpw obviously either.
and kinda dumb but how do i get seperate wall papers on two screens ?? 2005fpw + 17in crt. Nvidia did its dual screen config thing, and i have it set so they act as 2 screens etc but would like diff wall papers on each
uhm, on the USB, i am guessing that you have to plug the other end into your computer. Its a USB bridge.
And the Nview utility (nvidia drivers), allow you to have separate backgrounds for each monitor.
yeah there should be a usb cable for the LCD. Just plug it into usb port then to the LCD I think it is beside the VGA or DVI connector on the monitor.
For multi Screen you might want to check out ultramon it is great I love it.
is it full speed or w/e ?? cuz it would help if i can throw my mouse in there, as a serious gamer i cant loose dpi either so ...know what i mean >??
where at in the nvidia driver options... ive already had the nvidia wizard set it so they act as two diff displayes (drag somethin from one screen to the other) but dont see anythin about desktop wall apapers
