Dec 14, 2018 #1 D Dosobye Limp Gawd Joined Jul 29, 2010 Messages 400 On a ASRock b450 fatal1ty and 212evo, getting around 55c idle. Is that normal for this cpu?
Dec 14, 2018 #2 A atarione 2[H]4U Joined Mar 17, 2011 Messages 2,300 for various reasons .. the 1700X seems to report temps 20C higher than actual chip is actually experiencing (wth amd)?? sooo your numbers are ~frequently seen / fine I guess? apparently if you check temps with the newer versions of ryzen master software it shows actual core temperatures
Dec 14, 2018 #3 Pieter3dnow Supreme [H]ardness Joined Jul 29, 2009 Messages 6,784 Should be fine they did it due to fan speed profile
