I am helping a buddy with a PC build. For the most part the PC is configured, but I wouldn't mind some second opinions on this before he purchases everything. Questionnaire and current config below:
PC will be in the living room so it will have some HTPC function, but also using programs like Photoshop or Solidworks. Little to no gaming.
$1000ish (soft)
Nebraska
Everything in the tower + TV tuner and Win 7. Peripherals not necessary in budget. See config below.
All new.
6) Will you be overclocking?
No. Ultra quite is precedent due to living room location, however.
1920x1080
Within the month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Looking to use a Z68 mobo for LucidLogix Virtu for video encoding, otherwise discreet graphics.
Will purchase 64bit Win 7.
(Case Undetermined at the moment)
Mobo: ASUS P8Z68-V LE
CPU: Intel i5-2500
RAM: Corsair Vengeance 2x4GB CMZ8GX3M2A1600C9
PSU: Corsair TX650 V2
Video: Sapphire 100314-3L Radeon HD 6870 1GB
HDD: Seagate 1TB 7200RPM 64MB ST1000DM003
Tuner: Hauppauge WinTV-HVR-2250 MCE (no cable subscription)
CD/DVD: LG Blu-Ray UH12LS28
OS: Win 7 64bit Home OEM
Current subtotal: $1053 + case
Does all that look like pretty good bang for the buck hardware? Any suggestions for changes? Thanks guys!
$1000ish (soft)
Nebraska
All new.
1920x1080
Within the month
CPU: Intel i5-2500
