compslckr said:i use them and the soft mod (sapphire 9500 np to 9700) worked perfect with these drivers and not with the early versions of the "wizard mod drivers"
i like the omega drivers just for the built in soft mod and soft mod switcher thing, it is nice to be able to swtich between soft modded and stock depending on what you are doing at the moment.
there is no trouble installing the drivers, it would probably take as long to install them as it would to post your message. what video card are you using by the way?
