I have more noobie questions:
CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Produc...82E16820145043
A newegg.com Customer review (actually several) claim:
Pros: Have it up to 1200MHz! That's a 12.5% OC.
Cons: None
Other Thoughts: Timings have to be set to 5-5-5-15 2T & 2.2v or you won't get a hair above 800MHz.
How do I get this?
I see the option in there, but are many more options in BIOS then just 5-5-5-15 2T...
Currently CPU-Z says (I set it to 800 Mhz and it is Linked option selected):
Frequency: 398.9 Mhz
FSB : DRAM: 11:13
CAS# Latency: 5.0 clocks
RAS# to CAS# Delay: 5 clocks
RAS# Precharge: 5 clocks
Cycle Time (Tras): 18 clocks
Bank Cycle Time (Trc): 22 clocks
Command Rate: 2T
How do I get 1:1?
So In the bios (do I make these changes):
Memory Clock (Mhz): 1200 and use Linked option, or do I use Manual?
Memory Timing: Manual or Linked or Unlinked?
tCL: 5
tRP: 5
tRAS: 5
tRRD: 15
tRC: Auto
tWR: Auto
tWTR: Auto
tREF: Auto
Comand Per Clock (CMD): 2T
Memory Voltage: 2.2V
Any help appreciated. Thank you again...
Cons: None
How do I get this?
FSB : DRAM: 11:13
Command Rate: 2T
How do I get 1:1?
tCL: 5
tRP: 5
tRAS: 5
tRRD: 15
tRC: Auto
tWR: Auto
tWTR: Auto
tREF: Auto
