Greatone123
- May 10, 2006
I've desided that I really need a small low power system to do just daily stuff on, and I'm talking like... grandma's daily stuff... surf this forum, check e-mail (MS Outlook).
Reason I need it is, I think my system uses up too much electricity and puts out WAY too much heat (P2 940, 2x 4870 1GB in Crossfire +other stuff)
when I game I game a LOT... but it's usually in spurts.
here's what I tossed into my cart
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811154091
MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813121381
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116039
Mem: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Would I really need any more then that for XP Home, and basically running: Firefox, Outlook, and an AV program? Maybe Ventrilo or Messenger for communications...
I know the celeron is a single, but I was really trying to get the coolest, lowest power system going...
I'm might be willing to upgrade on the CPU I know the 1500 is cheap and 65W but only if you seriously think it can't handle what I wanna do...
oh ya, 250GB 7200 seagate? or a 60GB OCZ Core Series SSD? (I have both not going to buy a HDD)
budget is as low as possible (house, car, utilities... kinda more important)
