never been good at oc. need help!
Good Lord
Hello everyone,
I've been overclocking these 2 PCs
Giga DS3 rev 3.3/ Asus P5N32-E-SLI
E6300/ E6300
Enermax liberty 400W/ Enermax liberty 620W
Stock cooling/ Zalman CNPS9700NT
Geil 667 2g dual channel/ Geil 800 2g dual channel
Never got farther than 0.2GHz increase, or it hang. Pathetic right?
Please help me out teachers. Thanksssssss
PS. -I did carefully increase the fsb 1-3mhz each restart
-I carefully increased the Vcore little by little as 0.025-0.05, i finally hit 1.375 normally my Vcore is at 1.213
-I never mess with ram config. in the bios, only the RAM voltage which i carefully increased
My rig has none of the tempo problem, i got a decent venting, my rig temp is around 28-45 55max.
The link is very nice tho i'll be taking sometime to finish reading it.
Thankssss SDraconis
good lord. Make sure you have the essentials first.
ITAT to measure temptatures.
Orthos - to run stability tests after overclocking
And info is needed. What are your current settings. You need to elaborate what your doing. NEVER TRY TO OC . IF you do not know what your doing. You may risk damaging parts.
Soo Info needed. Current numbers in bios.
VCORE
FSB
MEM Voltage
etc etc etc
I've been overclocking 4 systems already none of them work perfectly, I have an average knowledge on OC.
I'm overclocking the gigabyte ds3 BIOS F9 rev 3.3 right now. I got it up to 2.1GHz now after reading the link SDraconis sent.
-I set all the voltage to auto as the mobo suggest (if set to manual), and Vcore is at 1.398
-I set the RAM ratio to 1:1
-Multiplier 6 x FSB 350 = 2.1GHz
-OC on intel stock cooling, temp is quite high 66C
-I've downloaded the essentials as the link suggested (CPUZ, TAT, CoreTemp, Orthos)
