Netzon: Netcase, a console style aluminum case
Discussion in 'Worklogs' started by Netzon, May 27, 2017.
  1. Netzon
    Netzon n00bie
    15
    Apr 26, 2017
    Hi everyone,
    I wanted to share my ideas for a console style SFF aluminum case.
    Background
    My company designs and makes datacenter solutions for cold data storage, with a sheet metal workshop inhouse. After discovering the SFF community on Reddit, I pitched the idea to some friends (who are all gamers and LAN party enthusiasts), who had never heard of SFF before and were intrigued. I decided I wanted to make a small batch of cases for my friends to test the waters.
    Preliminary Specs:
    • Dimensions (H x W x D): 351x70x310, 7.6l
    • CPU cooler clearance: 47mm
    • GPU: Up to 305mm in length
    • PSU: SFX
    • Drives: 2x 2.5"
    • Material: 1.58mm aluminum
    [​IMG]
    Extra vents added to the GPU and CPU side to improve airflow. Vents are also increased in density now.
    [​IMG]
    I've looked around a bit regarding the front IO, and it seems like I was a bit optimistic when it came to USB+Heaphone+Mic.
    [​IMG]
    The GPU sidepanel has some vent holes added to it as well. I'm not entirely certain on the placement of the company logo yet, so that may change.
    Changes 5/31/2017:
    • Further reduce the size. 8.1l is still pretty big, and ideally, we can get it in the 7.0-7.5l range. Reduced from 8.1l to 7.6l.
    • Add additional vent holes to the side and front of the GPU bracket to allow for better airflow. Additional vent holes added and density increased.
    Upcoming:
    • Design a stand for the case.
    • We will manufacture our own shielded riser and test it against some commercially available ones.
    • Manufacture a prototype.
    Derf likes this.
  2. Netzon
    Netzon n00bie
    15
    Apr 26, 2017
    Placeholder for the future
  3. Netzon
    Netzon n00bie
    15
    Apr 26, 2017
    Changes from 5/31/2017:
    • Size reduced to 8.1l to 7.6l by reducing the depth by 20mm.
    • Additional vent holes have been added to the GPU and CPU panels.
  4. luisxd
    luisxd n00bie
    18
    Nov 26, 2014
    Seems pretty simple... i like that, good luck :D
  5. Kerbalnaught
    Kerbalnaught n00bie
    7
    May 30, 2017
    Am I missing something obvious? I can't see the radiator for that Corsair Waterblock...
  6. Netzon
    Netzon n00bie
    15
    Apr 26, 2017
    That's just a placeholder for the drawing! The finished case will support aircoolers up to 47mm, though I am considering cutting out the third drivebay to allow for a 92mm/120mm AIO. Using an AIO would limit you to a shorter GPU though.
