rotteneggz
- Apr 12, 2004
[H]ello people,
If have a small home business with approx 4 people that use computers and need to access a quickbooks company file and other documents. At the beginning, i used a computer to host all files/quickbooks and used workgroups to share the files and folders to all the computers. After 8 months i decided to update the network config and add a dedicated file server to host all shared documents. The computer i got was an old workstation dell precision 650 with these specs:
Processor Intel Xeon 2.4 GHz
Chipset Intel E7505
Installed Memory 512 MB
Operating System Microsoft Windows Server 2003
HDD 36Gb Scsi Drive & 160gb IDE Driver
I use the Scsi drive for the quickbook files and the ide for other file storage/shares.
This file server is connected to a dlink router which links all computers together.
The problem i am faceing is that quickbook access is REALLY slow and so is other file and folder usage on the file server.
Now on to my questions:
1) Is a domain server faster then useing workgroups or does it just give more functionality to the server as admins?
2) I am about to add a smoothwall box to replace the dlink router, and a procurve 1700 switch. Will this addition help speed up the transfer and access of files on the server?
3) Does the network need internet connection? Or can the network work without the internet?
4) One of the computer in the network is haveing trouble accessing files on the file server. Primarily audio files. For some reason it is cutting the audio on playback when they run perfectly fine on the other computers on the network. What can the problem be? Does it have something to do with data integrity? if so how can i test that?
Thanks
Rotteneggz
Chipset Intel E7505
Thanks
Rotteneggz
