Networked printer won't print
hedron
If I log into my Linux server (Slackware 12.1) I can print fine. I have a CUPS printer shared with samba. It has printed in the past with the exact same setup. So, I am convinced that the problem is not on the server side. The only thing that contradicts this assumption is the fact that it stalls when I goto printers > modify printer > then when it gets to the "Make/Manufacturer" page and I select HP and click "continue" it stalls.
But from my windows machine, when I click print it says, "preparing..." then the pop up disappears and nothing happens. The print job does not show in the printer explorer.
Also, in printer properties > ports > there are no ports selected and I can't select one. Although, I'm not sure I'm supposed to be able to do that anyway. Just thought I'd mention it.
If I connect the printer directly then it prints fine. Makes me wonder why I'm even bothering, but whatever....
This shows up in my CUPS error log:
Code:
E [09/Dec/2009:20:15:04 -0500] Unsupported character set "iso-8859-1"!
I [09/Dec/2009:20:15:31 -0500] Started "/usr/lib/cups/cgi-bin/admin.cgi" (pid=15242)
This is in my CUPS access log:
Code:
[09/Dec/2009:20:15:34 -0500] "GET /admin/log/error_log HTTP/1.1" 200 1054709 - -
localhost - - [09/Dec/2009:20:16:04 -0500] "POST / HTTP/1.1" 200 196 Get-Printer-Attributes client-error-bad-request
Page log:
Code:
The_Docks hedron 69 [04/Dec/2009:22:12:59 -0500] 1 1 - localhost
It shows those over and over again.
The printer is an HP D5160 Photosmart printer.
Any ideas on how to fix this issue?
