IveBeenBad said:I just finished doing my setup today. What I did:
Centralized in computer room closet - Motorola Surboard, Linksys 4-Port Router, and Dell 16 Port Switch.
Coaxial cable comes into the computer room throught a splitter to the Modem, the LAN cable from the router goes to the WAN port on the router, and the Uplink on the Router goes to Port-1 on the switch.
I ran 3 drops into my bedroom, 3 drops into the computer room, and 1 drop into the master bedroom. I used keystone jacks and plates from www.cat5direct.com .
If you want any pictures let me know.
mjcason said:How is your cable signal with the splitter, 99% of the time you will get very bad signal (cable light going out at random times?) i just ran in a new line for the modem cause i was haveing such bad signal issues (my speed is 3GBs vs 1.25GBs on the split line).
Arju said:Wireless sucks for consistancy... my signal is really weak and wireless is slow.
How can I wire up my house? My basement is finished and I need to go from basement to second floor
Any good Toronto installers you guys can recommend?
