Network Setup
h0mez
Sorry for the following noob questions, but heres my setup.
3 esxi servers, one with an OpenSolaris VM with my NAS where all my VMs are sitting on and other media. An 8port unmanaged switch, all 3 servers have 1 connection each to the switch along with a bunch of stuff, then its connected to my router. I am getting like 35mb/s read/write on the VMs to the NAS, which isn't good, I did know that would happen.
So I bought a Dell 5324, and I don't know how I should set everything up. I want to do 4-6 connections from the NAS server to the switch, and then dual connections from the other two servers. From what I've been told/read, I should setup a VLAN specifically for those 3 servers.
My question is then, whats the best way to hook up the rest of network(2 machines, 3 360s for WMC). Do i keep them on the 8 port switch, and then connect that switch to the VLAN? Or do I run 1 cord out from the NAS server to that 8 port switch? How do I connect my router up to the switch(es)?
I need to read up on this stuff, but haven't a good resource yet that covers everything, I've been going through a ton of threads just trying to figure out what everyone else is doing.
You can connect everything to the 5324 without issue. You can even leave everything in the same VLAN if you wish. The only benefit to separating the ESXI servers from the rest of your network is security. Do this if you want to limit the networks access to those servers.
I have to question why you believe you need to run multiple connections from your NAS? Have you tested your speeds with the 5324 in place instead of the old unmanaged switch? Multiple connections to the switch can help if you have a lot of systems trying to pull from the NAS at the same time, assuming the NAS can handle it, but I have to question if your NAS has the horsepower to keep up with multiple gigabit links.
Put the 5324 in place of the unmanaged switch, in the same configuration you were running, and see what speeds you get.
With a trunk link you are still limited to 1GbE link from the server to the client. So if you only have one or two clients connecting to the server using a small amount of bandwidth it will not help. If you have a more clients or clients using the whole 1GbE pipe it can help if the NAS can support it.
What are the specs on your server?
VLANs are used for logical separation of networks, they create separated broadcast domains. This means that if you are going to setup different VLANs you will need a router to communicate between the VLANs.
Right now in my home lab I have three VLANs that go outside of the ESXi server. My main network, storage network, and the external internet. The only one that has a route between it is the external to the main network. I am in the process of moving my router to a VM.
I would first work on getting the switch working with everything on a single VLAN and if you find a need go from there.
The specs on my main server is Supermicro X8DAH, Intel X5650(at some point i'll have 2), 72gb ddr3 ECC Reg(will be 120gb when I get the 2nd cpu), then I have 4 2tb WD Reds in a raidz1 setup and a 40gb SSD. I can give the NAS as much power as it needs, which I don't what that would be.
My other two servers are ASRock H77 Pro4-M, Intel Xeon E3-1230 V2, 32GB DDR3 desktop RAM.
Right now, I have VMs sitting on the 2nd and 3rd servers HDs, I want to get rid of those HDs and put their VMs on the NAS for DRS. So I was going to run multiple connections to switch from the NAS, because it needs to share those VMs over the network to 2 servers, plus whatever other media im streaming from the box. So I figured 1 port per server(2), then the other ports for the rest of the network(total 3+).
Okay so no VLAN, I was under the impression I wanted one to reduce collisions, as to increase performance to my 2nd and 3rd servers
So you main server is an ESXi host with a storage VM? I am guessing you are passing the controller to the VM, what are you specs on that VM? You should be able to get much high speeds with that hardware and an SSD.
I would first connect everything to the new switch like you have it now and then test everything and see if that is your limiting factor. Then start setting up the trunks.
Right, the specs right now are kinda weak. I'll up it when I get the switch setup. Thanks!
Ok I'm not doing something right...
