The GT uses a regular PCI slot so be aware that the maximum bandwidth your entire PCI bus (all your PCI slots combined) can provide is 1Gb. That's why you want PCI-E network adapters so the bus isn't your bottleneck.
the quad GT is a PCI-X card, he's fine.
If he plugs it into a PCI-X slot. Otherwise you're limited to the 1Gb PCI bus.
his machine has the following slots:
3 PCI-X slots: One 64-bit/133 MHz PCI-X and two 64-bit/100 MHz PCI-X
he says what server he has right there in the OP. check it out.
Perfect. Then he doesn't need to worry about it. I have no idea what slots a DL385 G3 has. I just wanted to point out that if it has no PCI-X slots then you have to deal with the PCI bus bandwidth limit.
