Network Problems
shivang222
Hey guys,
After recently building my computer i set up an internet connection and everything was going fine. However, all of a sudden after restarting the computer once, it would not connect to the internet. I am using a broadband connection with a router. The laptop i am using right now connects to the internet fine, but the desktop keeps saying that connected an unidentified network, that wont connect to the internet. What should i do?
Might not be hardware related, could be corrupted software, spyware etc but rule out the obvious first is always the best step:
Have you been into the BIOS and made sure the onboard LAN is enabled (you're using the onboard LAN right?), check device manager and make sure theres no ! on your LAN.
I've read about some mobo's having iffy LAN recently, though I stress I have no idea if yours is one of those models.
How do i check if onboard LAN is enabled i see no option in the BIOS...
Also, there is no exclamation mark in the device manager...
Right I've just had a look in my BIOS, its probably completely different but I hope this points you in the right direction.
My on-board LAN (disabled) lives in:
Integrated peripherals>Onboard PCI Devices>Network Controller.
I found something called mac0 lan and mac1 lan and they were both on auto not disabled.. so think the bios enabled them...
yes, ther is the nvidia networking controller and the nvidia network controller #2.
Have you tried disabling the adaptor and using the other? Perhaps uninstalling the network card drivers and rebooting so they can be redetected.
I tried the disabling thing, but how should i go about uninstalling the drivers? should i just go to device manager and unistall the driver? what if i want to get them back?
If you have already tried the other ethernet card then perhaps trying a different network cable.
i tried switching cables and it did not work...
are there any other alternatives? sorry to bother you guys... but its really pissing me off how it worked on second then after restarting it stopped working...
You could try running the Network Setup Wizard again. Are you getting an IP address from your router?
Power down everything, cable or DSL modem, router and PCs. Then power up the modem and let it run for a minute or two. Then power up the router and let it run a couple of minutes. Finally power up each of the PCs one at a time. If you still have problems then here are some things to check. Is DHCP enabled on your router? Can you get to the routers setup page from the PC with the connection problem? On the problem PC open a command window start - run - cmd enter. Then run ipconfig/all, assuming you are running XP. The default gateway and DNS server IPs listed should be your routers IP address. If you have 0.0.0.0 for DNS thats why you can browse the LAN but not the WAN. If it is 0.0.0.0 first thing I would try is reseting the router to defaults. Don't forget to reset the password.
DHCP is disabled..
it says physical address is 00.00.00.00.00 something like that
and it is empty for DNS suffix and default gateway..
btw im running vista..
OK, I have no Vista experience and no Vista PC to check settings on. :(
DHCP is disabled where, on the router? If it's disabled on the router and your network connection on the PC is set to automatically acquire an IP address you won't get one. The router won't assign IP address to PCs if it's DHCP function is disabled. The "physical address" is the MAC address of the network card, 00.00.00.00.00 does not look right. The MAC address is hardwired into the card to identify it and as far as I know should never be all zero's. May not be related to your problem though, not sure. Did you do any windows updates prior to this problem cropping up? Driver updates from windows update are notorious for breaking things in windows.
If it is Vista, then you got a pop-up that asked what type of network are you connecting to, till you click on one of the options it won't really let you out to the internet. Select Home network, and you should be fine. If you don't see this box on your screen check your Networking Control panel. Unfortunately I don't have a Vista box to check on this anymore, so I am going off memory.
Good luck.
I didn't get that option. Where do I find that option? I only see Private and Public of which neither of them work.
Should I try to reset my router?
Sounds like a Vista problem to me but you could try reseting your router. Don't forget to set your password and if you had any port forwarding etc, setup you will have to set it up again.
Anything to do if it is a Vista problem.. because when i tried to connect this computer through ethernet, it worked fine and this is an XP laptop... so it could be Vista...
If I read your last post correctly..your XP laptop works fine but your Vista PC doesn't? That would indicate to me that it's probably not a router problem. Can't help you with Vista, I don't have a Vista PC to poke around on.
