EvilSmiley
- Oct 18, 2001
Heres the situation:
I'm renting a garage apartment from some friends, and they've got cable. So we decide to find some way to get me on their network.
The way everything is setup in the main house is such:
Modem -> Router1 -> Comp1 and Router2 -> Comp2
The only reason router2 is there is it is a wireless that was given to us to try the wireless route, but I couldnt get a signal. I took the router out to my apartment, hooked up it right next to my comp (now referred to as comp3) and got a 77% signal strength. I moved it to the front door of my apartment and it dropped to 22% signal strength (thats just under 10 yards).
So I figure too much interference, and decide to run a 100' line between my comp3 and router2. Now this is whats going on:
My comp3 tells me that the cable is connected, but cannot recieve packets. Tries to send them, but doesnt recieve any. It does not recognize any network, unable to get an IP through TCP/IP, so no repair.. I manually assign an ip, and still nothing.
if I try to repair, I get that ARF (?) IP of 169.254.x.x -ish.. is that right? cant think right now, sicker than a dog.
So, any ideas? I tried switching ports on the router, so its not a bad port. Is it possible that there is so much interference that it would mess with a land line? or could it be something with the routers? Im at a loss here.. every other time I've hooked up to networks, it went fairly smooth and painless.. never ran into this problem before. Any help will be greatly appreciated.
