Liquidkristal
- Dec 17, 2000
ok, so i've been asked by a customer to quote for an IP PBX for their site (High School, 1600 pupils, 100 handsets, thats not the issue)
the problem is their network is a huge collection of 24 port 3Com switches, some have gigabit, some don't, its spread over 6 wiring closets, each closet is connected back to the IT room via fiber (8 core) so thats not really an issue, its what to replace it with.
The current 3Coms all work, but there are complaints that its slow (and with no QoS), the phones will work, but its far from ideal.
I am looking at replacing the 3coms with HP procurve chassis as the back plans support far higher throughput than stacking switches, now the main comms room as 408 ports at the moment, the biggest HP can do 288, so, my current plan is to put a 42xx series in as a core with fiber for connecting everything else to, and a single block of Gige copper (server connectivity), then running 42xx's / 28xx's everywhere else and using injector bars for the PoE.
Does my idea suck, are there better ways around it? (cash is an issue as they are a school, so cisco is out of the window, but they do appreciate that they have been nursing the network along now for nearly 6 years and it needs fixing)
looked at the 5400 series, but its a bit expensive..
Network port counts per closet are
Closet 1 - 408 (also houses servers)
Closet 2 - 120
Closet 3 - 96
Closet 4 - 72
Closet 5 - 72
Closet 6 - 24
any ideas are appreciated.
Closet 2 - 120
Closet 3 - 96
Closet 4 - 72
Closet 5 - 72
Closet 6 - 24
