velusip
- Jan 24, 2005
Shaw Cable tech support was no help regarding my erratic WAN status (updownupdownupdown). The next thing I did was point a fan at the cable modem. Sure enough, the rapid switching calmed down. Regained stability about 10 minutes later.
Calling back to inform them of my victory, Shaw mentioned a common issue with bad power adaptors too. So there you have it: If you're having a computer problem it's probably power or heat.
I hope this info serves someone well. I've always lived in cooler climates than this and kept my place sub 18 degrees celcius, but since I moved to tropical Vancouver BC it seems that I'm going to have to beef up my cooling systems, even for network appliances.
