ByteDown[H]ard
[H]ard DCOTM August 2026
- Apr 4, 2001
I have been having trouble the last few weeks with network outages in my little 17 node home network. I am using a 16 port Linksys switch and a 5 port linksys switch. The gateway(running windows ME, yea, I know) is connected to the 5 port switch along with my main machine. The 5 port switch is connected to the 16 port switch where all the other machines, (all running ME or XP Pro), are connected. Now and then all the machines loose network connectivity, EXCEPT the two machines connected to the 5 port switch. If I power down the switches for a few then bring them back up, everything works fine for a few hours/days/week. then it starts all over. I thought the problem might be the 16 port switch so I used several 5 port switches it replaced, same problem. I don't have a cable scanner so I all I can test is the continuity of the cable connecting the two switches and it comes up green on all pairs. Not sure what else to try aside from rebuilding each machine and taking care of the network settings manually instead of letting microsoft do it automatically, not sure if ICS is the culprit.... Any suggestions would be appreciated...
