Network noob seeking advice
Wingy
Hello,
I'm setting up my home network, and could use advice on accessing it from the outside world.
I have 4 Machines, A, B, C, D. A is my laptop. B, C and linux boxes, D is Windows 7.
Everything is behind a little linksys router/firewall/switch.
My question is this: Should I setup the servers on each of the boxes to routed to by the router via port forwarding, or should I use one of the boxes as a dedicated entry point to the network.
My idea was this: If I mount the drives on machined C and D on B, then when I go to the the coffee shop with A, I can basically SFTP my files and what not to B, which will distribute as necessary.
I hope that made sense, it makes sense in my head. Dedicated SSH, SFTP on one server with file systems of 2 other servers mounted to it for distribution, or simply setup SSH, SFTP on all 3, and use the routers port forwarding.
Thanks
Why not just setup network sharing?
you remote in and see the shares using SMB in linux.
Network sharing was essentially what I was talking about.
smb shares mounted to the server, which I remote in to. I wanted to make sure this was the best approach.
