lostgunman
- Jul 16, 2004
Ok, we are building a Pc to monitor multiple ports on Cisco hardware. Our only issue so far is trying to be sure it adds very little latency to the network ports we are monitoring.
We have never done this before.
We need a system that has 5+ gig network ports in it. I have found a couple that may work (byo systems), and our network admin keeps pushing high end stuff when I do not think it is needed.
The plan was to keep it cheap...but really good. I was using newegg to find the parts. I figured I needed a motherboard that had Athlon X2 ability, SATA II and 2 on board gig NICs to start. (still looking for a good one)
I would then need the ability to cram 3+ other gig cards into it. (wanting as many as possible).
First, can PCI really provide enough UMPH to push gig? Second, has anyone used more than 2 NICs in a system before (higher the better) and if so how well did they perform? I know PCI Express has the push to do gig, but I can't find many boards with a lot of PCI x1 slots, and all I can find for PCI Express gig cards is a D-Link (want a better vendor). Next, is it possible to use the x16 slots on a motherboard (normally for video) for x1 network cards? Then, does someone know where to find PCI Express multi-port gig cards?
thanks for any help.
