I have an ASUS P6T SE motherboard, and am running Windows 7 64-bit.
The issue I'm running into is related to the network card. Sometimes when I boot up, it tells me there is no network cable connected... or when it does try to connect, it will connect at 10mbps. Usually I can eventually coax it into running at 100mbps by a combination of unplugging / replugging in the cable, disabling/re-enabling the NIC, running the diagnostics, and finally a reboot. Unfortunately, it eventually starts acting up again after several cold reboots.
Plugging the same network cable into my Tablet PC (Elitebook 2730p) causes zero issues at all -- it always detects at 100mbps). I also had zero issues running this on my old Maximus Formula motherboard.
I'm willing to accept that a potential failure could be happening with the in-wall network cable (we wired our house for Ethernet about 10 years ago using regular Cat-5 cable), but wouldn't that affect all systems connecting to it, rather than just this particular board? Just to clarify, when any system connects at 100mbps, I get the bandwidth I should.
