So I'm wiring my house up soon and decided on doing a lil' future proofing by going with Cat6A cabling. The particular cable I've chosen is shielded and will have to grounded out somehow in order for the shielding to be effective.
I've found a inexpensive "blank" keystone shielded patch panel that has the grounding wire coming off it to attach to....what exactly?
The patch panel will be connected to a wall via a swing out bracket so its pointless to attach it to that. Do I get some sort of wall out let adapter and ground the system out through the house mains or what?
Or am I going about this in all the wrong way?
TYIA
edit: So I finished getting the house wired up a ways back and everything went smooth. The ground wire ended up getting ran from the breaker box/house mains ground and out to the patch panel. Despite all the predicted horror-show it wasn't all that difficult to run or terminate the shielded cable. Everything was ran by professionals but the actual termination was done by myself and I'd never done a shielded connection before either. Took me about 5 hours to terminate and test everything. The only quirk in terminating them was making sure the ends of the conductors were trimmed almost perfectly flush so they didn't come in contact with the shielded portion of the keystone. A small set of angled snips works perfect for this.
TYIA
