I have a small home network with a Netgear (FWAG114) router. I have a desktop PC and a home theatre PC each with Windows MCE and a laptop with Windows XP Pro connected in a workgroup. All are wired connections. For some reason only some of the folders on the desktop PC can be accessed from my laptop. Others are fine. If I enable sharing on some folders on the desktop PC, I can see it from my laptop under My Network Places -> Entire Network -> Microsoft Windows Network -> workgroup_name -> computer_name but if I try to open the folder I get error dialog "xxx is not accessible. You may not have permission to use this network resource." I recently built a new desktop computer (before that all my network folders were accessible). I named the computer the same name, same workgroup name, etc. I went from Windows XP Pro to Windows XP Media Center Edition but they are basically the same except for the domain issue. Also, the only difference I can think of between the accessible and inaccessible folders is that the inaccessible folders are on my main C:\ drive which is now a RAID 0 configuration consisting of two SATA drives (it was a standard IDE drive). Should that matter? Is there some place on my laptop where information about my networked desktop PC is located where it might be confused with the old PC drive structure? Can I delete all the information about my desktop PC and reset it by searching the network?
I have run the Network setup wizard several times. I have set permissions both with and without simple file sharing. Both computers can access the Internet. Both computers can access my HTPC. I can access the desktop PC with Remote Desktop and radmin.
Please let me know if you need further information. At this point, I'm stumped.
Thanks,
Ferris1
Thanks,
Ferris1
