Javelin3o4 said:where is the unit located is it a 2 level house? and the unit is downstairs and you are upstars? how far away are you from it?
I had a friend who had one of those netgears he got a low signal from the damn thing and it was approximately 30 ft. away, lately ive been hooking up netgear crap for other people and in my opinion it sux.
Phandalyon said:Ok, I am going to attempt yo translate your thread into english. Let me know if I am on the right track.
You have a Netgear wireless router (it is not a modem) in your home. You have a one story house and the signal strength is very weak, even in the same room as the router.
Am I on the right track?
If so, what are you accessing the wireless with. Is it a laptop? Does it work with other wireless access points without any trouble or is this the only time you have tried using wireless. If this is your first time using wireless head down to a locla starbucks or Barnes and Noble and see if they have a wireless AP that you can try connecting to.
I have seen several laptops where the internal wireless card has the antenna disconnected or completely missing.
Also, if you have a friend who has a wireless laptop have him or her try accessing your network.
I use a Netgear router for my home access and I can use my Pocket PC to access the internet while lying in a hammock in my back yard. I have even used it at my neighbor's house. Wireless is never perfect, but you should get a decent signal if you are in the same room at the very least.
