Netgear SC101 Review? Experience?
willie92
OK, does anyone have any practical experience with the Netgear SC101? I've read some reviews that make it sound OK. But I'm wondering if there's anyone that has some [H]core expereince with it and can give me the real skinny on whether it's worth it or not...
:confused:
:confused:
I had one for about 24 hours. It seemed to work fine but I was not comfortable with the amount of heat it was putting out. After sitting over night you could not hold on to the top or bottom (it's like a huge heat-sync). It might be fine, but I'm not trusting 500GB of data with that much heat.
Thanks for the words TT. I'd read that this thing got a little warm, but I didn't realize it was that bad...'preciate the warning. :D
