I've got a question
. I was computerin' around today and decided to make a dual booter out of my E6600. (I have another E6600 CPU, just no mobo ATM) I'm going to install Ubuntu 64 v8.04 on one side (hda2) )and WinXP 64 on the other side (C:\). My question is I've updated everything but the kitchen sink through the M$ update site and it updated me to NetFx64, do I need the Microsoft .NET framework v2.0 to use the undependable PITA WinSMP client only temporarily? (I hope to get one of those "el cheapo" 9600GSO's)
I've had the E6600 doing the LinSMP client for a while with no problems, if I didn't hope to get another GPU card for the dual I'd have left it the way it was and used the WinXP 64 CD under the gravel in a goldfish bowel.
Thanks for any answer or advice. I read somewhere you could fold with the GPU2 client under WinXP 64
Edit: I must be getting old (nahh...) I forgot to ask if the Real Temp program works in WinXP 64, if it doesn't what is the best CPU temp program that does
Foldin' and WCGn' for a CURE
