Netevent.dll Error causing slow boot up.
Secular
I am running WIn XP Pro 64 bit, and it seems my nvidia drivers are causing a system error upon bootup, and it hangs my system for around 30-45 seconds before my taskbar shows up. I am running the 64 bit version of Nvidia's 93.71 driver. Here is the info from event viewer.
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7000
Date: 5/9/2007
Time: 5:21:42 PM
User: N/A
Computer: MAYHEM
Description:
The NVIDIA Display Driver Service service failed to start due to the following error:
The system cannot find the file specified.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Any suggestions would be apprecaited.
Edit: I have done a search for netevent.dll and it is in the system32 folder and the sysWOW64 folder. I copied it into the Windows folder and the system folder, but that didn't solve anything.
google groups thread on that issue
The proposed solution was:
try this:-
Start > Run > type "sfc /scannow" (without the quote marks)
Have your WinXP disk ready to put in. All system files will be scanned
and replaced if missing or the wrong version.
Best of luck
And the OP replied with a thank you, but did not say whether or not it fixed the issue...
have you tried a driver reinstall / update (to newer ones) ?
As far as I can tell those are the newest drivers available from Nvidia. I do however have Ntune installed, think that might be an issue?
I just built this computer monday, so it is a fresh install of Windows. Do you think I should still try that? I suppose it couldn't hurt.
Check the modified time on that .dll - and the version info from the file properties -> summary.
Perhaps the nvidia driver installation modified that file?
Thanks for the help guys, it looks like we got it fixed.
I reinstalled my video drivers and my nforce drivers.
The one thing that I did differently, from when I installed these drivers the other day was this time I let the Nforce drivers install Nvidia's Network Access Manager. I didn't before because I didn't think I would need it, but since the name of the file was NETevent.dll I thought maybe nvidia was looking for it and not finding it.
Again, thanks for the help and sorry I didn't think to do that before creating the thread.
