Nero CD Text
GUL
hi i need some help with nero cd text ....its not working basically and my cd player in my car does support cd text
also here is screen shots
this is the default screen i get when i click the properties and it says aspi not installed
if i click the drop down menu i get this nero aspi and it says it is installed how ever when i leave it as nero aspi it automaticly changes back to system aspi when i check again ?
heres a screen shot that shows my drive does support cd text
any help would appreciated
try posting the cd burning configuration screens from nero as you select options, add songs, and specify values for the "CD Text" text fields in the options window.
also, what version of nero? are you running the latest build of your particular version of nero?
