spectra260
- Mar 23, 2003
I have some video files that were MKV so I converted them to dvd with winavi and want to burn them now. After I converted them they all add up to 4gigs whitch is fine it will fit I figure on a 4.7gig dvd disc.
I load up nero 7 and goto add dvd video files and it says not enough space on the disc and that its almost 6 gigs size. But I check the files and the total size is only 4 gigs. Some how when I choose them with nero it ends up saying its much bigger.
I found out that nero 7 transcodes it or somthing and im guessing that is the reason why its making it larger instead of just burning the files. I had no problem burning DVD's with Nero 6 the only reason I got nero 7 was for I can make dvd menus for it looks better.
Is there a way to just make it burn the files thers no erason it should have to encode or convert it anymore sinse its already DVD files and I can play them fine with VLC player.
