[?] Neoware???
allenpan
[?] Neoware???
i got bunch of Neoware Thin Client with LCD build onto it
the spec:
Geode GX1 300 MHz
256MB Sdram
Winxp Embedded
the model number in the back says CA4 but i can't find any infomation about it, i need a bios update...can someone tell me the correct model number or where to look for...
i want to formate it and install linux..but is giving me some hard time...
the closes model i found is e300, but e300 is using VIA not AMD..unless i read it wrong...(frome the web i mean)
